I'm trying to use the potentiometer to control the brightness of the LED board. (everything works perfectly fine without the potentiometer)
Before adding the potentiometer to the circuit, I tested it with a single LED on a separate breadboard and it worked.
After the potentiometer was added to the circuit, it worked for like 1 minutes with me turning the potentiometer back and forth, then it started to make noise, smell and eventually spark was coming out too.
Here is the schematic:
I checked the voltage and current with multimeter afterward:
I= 0.058 A
V = 12.93 V
so, P= 0.696 W
Is it because the power is exceeding the potentiometer's limit (0.696 > 0.5)? If so, what would be the proper way of modifying the circuit (different types of potentiometer maybe)?
The model for this potentiometer is WH148 (B10k) and it has resistance of 10k, rated power 0.5W according to the website I purchased from.
I= 0.058 A
V = 12.93 V
so, P= 0.696 W
