Built-in Silvertone Guitar amp circuit questions
Discussion in 'General Electronics Chat' started by thedanimal, Aug 21, 2016.
  1. thedanimal
    Sep 19, 2009
    6
    Hi all,
    I've acquired a 1964 Silvertone guitar with a built-in amp that I'm trying to make functional again. I have the guitar rebuilt, but the amp circuit did not include the 2 9 volt leads to power the amp so I'm trying to identify how to hook up the new leads I bought to test the amp. Here's a pic between the amp on/off switch and the pots. Any help would be greatly appreciated as I'm just now learning about circuits.
    Dan
  2. #12
    Nov 30, 2010
    16,665
    7,310
    That picture shows no evidence of an amplifier so it's impossible to see where to connect the battery.
  3. thedanimal
    Sep 19, 2009
    6
    Here's the full circuit. The only picture I've seen had the leads attached to the pots and switch.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    It looks like a push-pull amplifier.
    It has two transformers in the amplifier.
    The circuit could be like this :
    It would be nice to know the part number of the transistors with the tabs on them.
    It is not possible to see where the power connections could have been.
    Is it possible to show a picture of the other side of the amplifier?
    Bertus
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Post deleted
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I have posted the image from the link to avoid unwanted images in the adds.
    (I am using add block plus to avoid unwanted adds and save bandwidth).
    Bertus
  7. absf
    Dec 29, 2010
    1,493
    374
    My guess is those transistors are PNP Germanium from the 60s'. They are probably made by Matsushita or Toshiba.
    Allen
  8. thedanimal
    Sep 19, 2009
    6
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I have made some remarks on the circuit drawing:
    The power switch can be mounted in the - line of the battery.
    Bertus
  10. thedanimal
    Sep 19, 2009
    6
    Hi Bertus
  11. thedanimal
    Sep 19, 2009
    6
    Hi Bertus. Thank you for your thoughtful response. I must concede that I am just getting started with electronic circuits and am early into books from Mims and Platt to learn more.That said, I'm not following your notes for how to hook up the leads. If you can please be painfully specific via point-to-point wiring from my original image I'd be very grateful.
    Regards,
    Dan
  12. cmartinez
    Jan 17, 2007
    3,698
    2,766
    A direct, high resolution close up image of the circuit from above and from below would be very useful in helping you out with that.
  13. thedanimal
    Sep 19, 2009
    6
    Thanks...I will work on getting this updated very soon.
    Dan
