Well, I decided to build a new project based on the "Quattuor" multimedia speaker system. I was aiming for portability and I was planning to use a couple of Visatons FR8. Then I've found that those drivers are a big no no when comes the time to calculate an appropriate enclosure (the values don't make sense and are out of range, for sealed enclosures, and for ported enclosures with different alignments). Well, it seems I have to use the FR10 instead, which means, here it goes portability.
I was planning to build this project using a single control knob for volume, hence dismissing the LM1036 chip. Although not aimed for portability, Unus would still have the advantage of being cheaper than Quattuor. Also, I've found that the LM1036 introduces a bit of noise.
My question is, is Unus worth to be built, considering that is essentially just the same as Quattuor, but only with one control knob, no LM1036 and less noise?
