srikanthsamaga
- Joined Jul 1, 2008
- 13
I have provided circuit diagram of that board in my website.Can you provide me list of components in that board??
You will get all the info you need in that.
Yeah. I know. I was being lazy!I have provided circuit diagram of that board in my website.
I'm not sure. But looking at that sunrom programmer I'm thinking of using 89S51/52.Which 8051 are you using?
Codes can by downloaded to the AT89C5131 (8051derivative) via USB from your PC. Alternative, the NXP 89LPC9xx uses serial port of your PC for program downloading. No additional programmer is needed.
Wow! that bunch of wires & IC's. Must be fun putting all together & get it work. Actually I wanted to build board myself....Lets see. I'll post it when I'm done. People are using Arduino, PIC etc. these days, but I'm quite fond of 8051. Dunno why! may be because It's the first uC I studied. BTW Thanks.here's a 68010 dev board I put together some twenty years ago;
Today I wouldn't think of such a task and prefer these guys;
http://www.ebay.ca/sch/i.html?_from...313&_nkw=atmel+32u4&_sacat=See-All-Categories
Download Flip and a USB cable and your rolling.
Yes. I have used the 89C5131 and 89LPC922. If your PC does not have a COM port, you can use a USB-Serial convertor. The image shows a 89LPC922 circuit which i have built. The small board is a USB-serial convertor. The 89C5131 uses Flip for downloading while the NXP uses Flashmagic. To get a quick start on building the board, you can refer to the Keil MCB900 evaluation board documentation.I'm not sure. But looking at that sunrom programmer I'm thinking of using 89S51/52.
But 89C5131 looks better option. Did you used it yourself? Need to look in detail on this.
And NXP requires serial...means COM port right? If so my PC doesn't have one. Thanks.
Hey do you have the circuit for USB-Serial convertor? Or the kit is readily available?Yes. I have used the 89C5131 and 89LPC922. If your PC does not have a COM port, you can use a USB-Serial convertor. The image shows a 89LPC922 circuit which i have built. The small board is a USB-serial convertor. The 89C5131 uses Flip for downloading while the NXP uses Flashmagic. To get a quick start on building the board, you can refer to the Keil MCB900 evaluation board documentation.
by Duane Benson
by Jake Hertz
by Jake Hertz
by Jake Hertz
