Building own 8051 development kit
Discussion in 'Embedded Systems and Microcontrollers' started by @android, Feb 25, 2012.
  1. @android
    Dec 15, 2011
    178
    9
    So guy's I've worked with 8051. It's kinda of my favorite micro-controller. Previously it was my college providing me with development kit & stuff. But now after completing my course had to search job. Now I've found one.
    But don't wanna loose touch with micro-controller's & programming.
    So I've been thinking of building my own development board with minimal features. Is is ok to build it on bread board or should I use general purpose PCB(Don't worry I know there will be bunch of wires but I'm good with soldering). Or you guys have better ideas??
    Here are my interface requirements....
    LCD, 7 seg, LED
    Some sensors
    RF module etc.
  2. debjit625
    Apr 17, 2010
    790
    186
    My first development boards where with varoboard then I shifted to PCB I built my own PCB at home.When I started I was 16 only,but after so many years the varoboard stuffs are still ok and running I didnt thought they will do so great as I have used them a lot.So you could use varoboard to do it.
    My first PIC16F84A development board on a varoboard,I did it on 2005 and it still works...
    But one thing you cant do high frequency stuff on them as they create many problems I have came accross ,so in that case a properly designed PCB is best.
    Good Luck
      File size:
      57.1 KB
      293
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I had always built my pojects on perf boards with point to point solder termination. But years ago I converted to SMT exclusively, which commanded building my own PCBs. These days I go directly online and order prebuilt systems. Money can't buy time.
  4. nerdegutta
    Dec 15, 2009
    2,565
    805
    My first home made development board:
    My second:
    I say go for it. Then you will be using your skills, and maybe learning something new.
    This was for the PIC 16f628.
    Sparky49 likes this.
  5. @android
    Dec 15, 2011
    178
    9
    Nice board.
  6. @android
    Dec 15, 2011
    178
    9
    Hey! Great stuff!
  7. @android
    Dec 15, 2011
    178
    9
    Please provide me list of components. I always forget something at the time of buying and regret afterwords :(
  8. nerdegutta
    Dec 15, 2009
    2,565
    805
    Thanks.
    To start the list:
    • ZIF socket
    • tactile buttons
    • Single in line (SIL) connectors to LCD
    • Socket for a MAX 323
    • Keypad
    • Seven segments
    • Buzzer
    • Other sockets and connectors.
  9. @android
    Dec 15, 2011
    178
    9
    Oh! Thanks buddy that will really help!
  10. @android
    Dec 15, 2011
    178
    9
    Plus, does anybody has circuit for burning program into 8051? I know I'll need to use max232. And yes I don't have COM port to my PC so how will I interface it with my PC? Is there any COM to USB cable available or will I be doing my own convertor.
  11. @android
    Dec 15, 2011
    178
    9
    I guess nobody uses 8051 these day's, because I was expecting loads of posts showing their own boards! Sad!
  12. srikanthsamaga
    Member
    Jul 1, 2008
    13
  13. debjit625
    Apr 17, 2010
    790
    186
    Most of the time I may use Microchip's PIC , but you guessed wrong ,8051 is still used in many places and in many places it have advantages over other mcu .Their are many specific forums for 8051 you can google for them. Here is one and with an easy ISP programmer.
    http://ikalogic.com/isp.php
    Good Luck
  14. @android
    Dec 15, 2011
    178
    9
  15. @android
    Dec 15, 2011
    178
    9
    The link is not opening! :(
  16. @android
    Dec 15, 2011
    178
    9
  17. nerdegutta
    Dec 15, 2009
    2,565
    805
    Works for me...:confused:
  18. debjit625
    Apr 17, 2010
    790
    186
    Use the url directly or do a google search on "ikalogic isp programmer"
  19. @android
    Dec 15, 2011
    178
    9
    Ohh! Now its working. May be network problem :mad: BTW really nice link :)
  20. t06afre
    May 11, 2009
    5,939
    1,222
    Atmel offers a broad range of microcontrollers based on the 8051 instruction set. But packed with a lot modern peripherals. Perhaps that could be an option for you.
