Hi, I'm looking to build a motor using my two 2"x2"x1" N50 block magnets (each has 320 lbs pull force). I'm thinking coreless due to the power of the magnets, and since I'm not worried about heat too much (the motor would only run for short periods of time). It's more of a proof of concept project, high RPM is the highest priority. I have access to a ABS plastic 3D printer so fabricating a casing of any shape is not a problem. I'll be starting with a 6v lantern battery for power and moving up from there.
tl;dr:
What is the best design for this format? The only motor I've built before is a iron core tri-pole. Thanks.
tl;dr:
