building circuit using a decoder
Discussion in 'Homework Help' started by facetten, Nov 2, 2007.
  1. facetten
    Nov 1, 2007
    11
    can anyone give me some ideas of how to approach this problem?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You will need more gates. One quad AND will not be sufficient. Some XOR functions will be necessary to evaluate the NOT conditions, as well as some NOR and NAND gates. One three input NAND, for instance, will be TRUE for X'*Y'*Z' as inputs.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    I think he/she meant to say that there is a 74xx138 available also.
  4. facetten
    Nov 1, 2007
    11
    there is a 74x138 available, well it's past the due days already, so i just connected the outputs to NAND gates
  5. Ron H
    Apr 14, 2005
    7,050
    657
    You should notice that you said "41x138" in your original post.
