Yes, I remember what you said about the charging of the boost cap. As I said in my reply post I was counting on HDEL and LDEL to make the high side go first, do I need to turn BLO high first manually?Your gates are ringing. This causes heating of the MOSFETs and the IC, and also discharges the boost cap(s) rapidly, preventing the high-side MOSFETs from turning on fully. Additionally, it looks like the AHO is going high before BLO; BLO needs to go high first. Remember the charging of the boost cap thing I was talking about in the 3rd to the last paragraph in my last reply?
You have not indicated what MOSFETs you are using, nor what your motor's run current and stall current is.
Do those 22Ω resistors need to be 1/4W, or will 1/8W be sufficient?
The problem is that the motor was ordered from Dayton, and has very little documentation whatsoever. We asked them for a datasheet and they sent us the "user's manual." From I measured, at 24v run current with no load is about 1A, moderate load is about 4A, and stall current is slightly more than 15A
I'm probably going to order some motor drivers soon-- this H-bridge is proving to be more of a science experiment.
