IMO, That is a very low design ratio, you may run into a problem.Ok, so I marked the drive wheel and motor pulley as instructed, and turned them. It appears that the rotation ratio is something like 2.3 to 1 (motor pulley rotations to wheel rotation?).
As for wiring, the instructions are somewhat vague? I mean to say that the motor has only two leads (red and black) and the controller has multiple leads that somehow are supposed to connect to these two? For instance, there are yellow, blue, and green phase wires coming from the controller, as well as red/black power wires, and then there the five hall wires(red, black, green, yellow and blue)?
You can hook it up to a 12 volt battery and see if it turns. But I'm pretty sure it is brushed.
Usually a optical or hall sensor digital tach signal.Any idea what the blue leads are for? I read somewhere else, that those are just speed indicators??
Ah, got it. I have a battery operated digital readout that's left over from the treadmill. I attached magnets to the flywheel of the motor while it was running, and it seems to be working?Usually a optical digital tach signal.
Max.
Sounds like your final drive ratio is too low.
Motors produce power as the product of (speed X torque), with a low drive ratio, the torque produced by the motor will need to be high, hence high armature current.
When the motor is more correctly matched to the load, it can produce more output power over the desired speed range.
Calculating the correct ratio is tricky, many variables to consider.
You guys are all right, so I've contacted a local heavy equipment sales/repair shop here in Calgary, and they may actually be able to provide me with a used dc motor controller from a forklift or something on that order?There are a lot of unknowns between your brushless motor and controller that may give you heartburn. I would stick with the simple brushed motor and a PWM controller like I posted.
Won't they only be 12v supply, 24v max maybe?
Max.
Once again, to clarify, you're talking about the ratio/difference in size of the pulleys/gears?You can use it, just that the motor will not reach maximum RPM and the continuous torque rating will be a shorter curve.
I would seriously look at setting the reduction to at least 10:1, even with the reduced top RPM you should get the travel rate you need.
Right now you most likely have ~ 12 revs for 30" of travel?
Max.
Oh I see...Reduction between the motor and the driven wheel, 12 motor revs for 30" of trolley travel estimate at present needs increasing IMO.
This can be done with pulleys with an intermediate shaft.
The compact alternative is a gear box or planetary gearbox, but you may not want to run to this.
Max.
2.3 revs/30", got it.That should read 2.3 revs/30''! I edited the previous post but missed this one.
SEM typically made Decent DC servo motors, it depends on the size of motor they were aimed for, I would have expected traction motors on a forklift, but this depends on what the function was on the forklift?
But I definately think you need to look at reduction, one way with belts is the intermediate pulley system such as used on a drill press etc.
What is your intended power source?
Max.
by Jake Hertz
by Jerry Twomey
by Aaron Carman
