Hello guys, can you please help me out in building an amplifier with about 5mV pk to pk to 5 volts. the frequency is of 1kHz to 10kHz. There is a dc offset on the 5mV signal, which is from an antenna. I have tried using op amps it doesnt seem to work as predicted, can i use BJTs or FETs?
i need to actually compare two same type of signals which should have different amplitudes with same waveform as the antenna are side by side. However the amplitude is too small.
