building AC circuit to power UV Bulb
Discussion in 'General Electronics Chat' started by ElectromagnetNewbee, Jan 5, 2015.
  1. ElectromagnetNewbee
    Jul 13, 2014
    69
    I have a UV lamp i want to power using AC 120 volt wall outlet. I believe from the specs pasted below i need to build a circuit for 99 volts and .355 amps, 30 watts. I know how to do this using DC, but not using AC cause of hertz required. Im using 24 gage copper wire.
    How many feet of wire does this circuit need to be in order to meet the power requirements to power the bulb, 30/35 watts? AC.
    here is the uv bulb specs that i need to build a circuit for.
    G30T8 - 30 Watt T8 Clear Germicidal Fluorescent Lamp G13 Base 99 Volt .355 Amp 35.16" Maximum Overall Length, 8,000 Average Rated Hours. Spectral UV 253.7NM
    http://www.amazon.com/gp/product/B008RN62ZY/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1#
  2. Brownout
    Jan 10, 2012
    2,375
    998
  3. ElectromagnetNewbee
    Jul 13, 2014
    69
    i dont have the money for a ballast. i have to used the 24 gage wire i currently have.
    how many feet of 24g cable required to power this bulb?
  4. #12
    Nov 30, 2010
    16,665
    7,313
    This is an arc lamp. It doesn't use resistance, it uses inductance to limit its current.
    How many feet of 24 gauge wire does it take to make .95 Henries?
    It depends on the shape and the core material which you have not provided in your post.
  5. ElectromagnetNewbee
    Jul 13, 2014
    69
  6. Brownout
    Jan 10, 2012
    2,375
    998
    Feet does not matter. You don't use wire alone. If you can't get a proper ballast, then you don't have a path to success.
    ElectromagnetNewbee likes this.
  7. ElectromagnetNewbee
    Jul 13, 2014
    69
    i thought i could just build a circuit rated at around 35 watts power and it would power up?
    Would DC power this UV light bulb??? or is it designed for AC only?
  8. wmodavis
    Oct 23, 2010
    737
    150
    Inches might work.
  9. ElectromagnetNewbee
    Jul 13, 2014
    69
    ??? inches of copper cable?
  10. wmodavis
    Oct 23, 2010
    737
    150
