I am brand new to electronics.
A guy is putting together a CNC Foam Cutter for me. He is wiring the CNC kit that controls the stepper motors and also the temperature board that controls the wire.
Originally, I was to come up with a 240watt power supply. After some discussions back and forth he has agreed to build in some components at his end -- full bridge rectifier, capactors, etc. I believe that his equipment will multiple the supplied current by a factor of 1.414.
I have to come up with a transformer - AC current in and output between 18-20volt, 6-8amp. I need to put this into a project box, fuse, switch.
How would I go about find a transformer that meets these requirements?
I would appreciate an online link or some guidance.
I live in Ontario, Canada. I assume that this transformer would be heavy and would have a high shipping cost
