Building a split power supply from a 12VDC source
Discussion in 'General Electronics Chat' started by eeprom, Feb 12, 2011.
  1. eeprom
    Feb 12, 2011
    I have a single 12VDC supply, and I need to break this into two supplies +4.5VDC and -4.5 volts VDC so that I can run some op amps. I could use some help on this. Thanks.
    ee
  2. R!f@@
    Apr 2, 2009
    8,791
    771
    Welcome to AAC.
    For that u need a DC to DC converter. Since you asking the question I do not think you can make one.
    Better buy a dual supply or try to make one from salvaged parts.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Rif@@, there are more options than that.
    eeprom,
    Is the +/-4.5v the absolute limits for your supply voltages, or could you use +/-6v?
    Do you know what your current requirements are?
  4. t06afre
    May 11, 2009
    5,939
    1,222
    What kind of current do you need. If you only need modest current like in mA range you may google "virtual ground circuit"
  5. R!f@@
    Apr 2, 2009
    8,791
    771
    I know Sgt..I was just starting to ask him what OP has and what level of experience OP has to make such a thing
  6. Jaguarjoe
    Apr 7, 2010
    770
    90
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    That is a low price for a useful device!
  8. Jaguarjoe
    Apr 7, 2010
    770
    90
    Sticker price on these are $60 or so.
