Building a robot
Discussion in 'General Electronics Chat' started by Gween-fwaker, Sep 1, 2008.
  1. Gween-fwaker
    Sep 1, 2008
    Right now, I'm still trying to design a circuit that, with the presence of a signal, the motor will rotate clockwise, and with the absence of that signal, the motor will turn counter clockwise.
    I personally don't see any flaws with my design, then again I'm not an engineer or anything remotely close to one
    If there anre any flaws, I'd like to know about them. Thanks
  2. blocco a spirale
    Jun 18, 2008
    1,459
    369
    I'm afraid your schematic made my head hurt.
    All you really need is a H-bridge where the input to one side is inverted with respect to the other.
  3. kammenos
    Aug 3, 2008
    127
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Take a look at Steve Bolt's H-bridge:
    http://www.solarbotics.net/library/circuits/driver_4varHbridge.html
    While you could use another of the 4 remaining inverters in the 74HC14 to allow control by a single line, I suggest it would be much better to retain independent control over each side of the bridge. If your motor is running full speed in one direction, and you suddenly swap the polarities on it, you'll get very high voltages and currents. It would be much better to hold both inputs to 1 or 0 to brake the motor to a stop before reversing direction.
    Bolt's design doesn't have reverse-EMF diodes. That would be a good thing to add. On each side, put a diode between Vcc and the motor, and another from the motor to ground, cathode towards Vcc.
