Building a RC filter
Discussion in 'General Electronics Chat' started by resilient, Mar 3, 2009.
  1. resilient
    Feb 2, 2009
    23
    Hi all,
    I'm trying to build a low-pass RC filter, but I'm not sure if I've picked out the right values for the resistor and capacitor. I'm trying to extract the sine wave from a sine wave modulated PWM. The PWM switches at 20kHz and the sine wave is anywhere between 1 to 100 Hz. I want to use a 10k ohm resistor and a 20nF capacitor. Do these values sound ok?
    Thanks!
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The formula for a RC filter is :
    If you use the 10K and 20 nF you will get a cutoff frequency of about 800 Hz.
    Greetings,
    Bertus
    gems_07 likes this.
  3. resilient
    Feb 2, 2009
    23
    Right, so will 800Hz be sufficient to extract the sine wave?
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    A normal RC filter has a decay of 6 dB / octave.
    The 20 kHz will be damped with about 30 dB. (estimated).
    The resulting sinewave will be fair enough.
    Greetings,
    Bertus
