Building a motor without permanent magnets and with a commutator
Discussion in 'The Projects Forum' started by bustrud, May 16, 2011.
  1. bustrud
    May 16, 2011
    My son has a project to build a motor without permanent magnets and with a commutator. Im not very good with this and need help.
  2. shortbus
    Sep 30, 2009
    4,084
    1,664
  3. Kermit2
    Feb 5, 2010
    3,838
    961
  4. Bernard
    Aug 7, 2008
    4,231
    414
    What are the rules? What materials do you have? How about tools- soldering iron? About minimum materials needed, " tin" can, wire coat hanger & 1/4 lb # 22-24 wire.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. Bernard
    Aug 7, 2008
    4,231
    414
    Mercury procurement: Just cut off end of about 100 8 ft. flourescent tubes and collect the mercury- turned in over an oz. ' used to use mercury to make low noise rotating contacts.
