building a microprocessor - time delay
Discussion in 'The Projects Forum' started by dottie, Jul 23, 2011.
  1. dottie
    Jul 23, 2011
    a year ago i thought it would be awesome to build myself a microprocessor out of discrete 74HC parts (I had no idea what it would be like). ATM I have a working ALU and memory unit, but I'm kinda stuck at a "SLEEP" instruction. I plan on adding a 8x8 LED array to my microprocessor, so I can play pong or something like that :)
    So I bought 8 SIPO shift registers and connected the LEDs. So to draw a complete "scene" (64 bits) it takes me 8 steps ... But here's the problem: I need to draw the scene, then wait for some time to get user input and then redraw. I figured it would be best to check for input, then sleep for some time and do that over and over, before redrawing the scene.
    I actually need some component, that stays on HIGH (5V) and when I trigger it, it would go LOW (0V) for some time and then back on HIGH again.
    I think the best would be to use some sort of binary counter, but I decided to ask the wiser :)
    Thanks !
  2. kubeek
    Sep 20, 2005
    4,689
    806
    If your procesor has conditional statements, then just make a while loop and count to some number before the program continues.
  3. dottie
    Jul 23, 2011
    Yeah, that was my first thought, but I only have 8bit addressing, so 255 instrucitons is probably not enought to make 1 sec delay. I mean it is, but it would probably take up all the space left for the program itself.
    PS: take jsem cech :)
  4. kubeek
    Sep 20, 2005
    4,689
    806
    What is your clock frequency?
    For example a triple-nested loop that can make a delay of up to 256^3 ticks should take cca 8-10 instructions.
  5. kubeek
    Sep 20, 2005
    4,689
    806
    Here is a loop example in pseudocode, it should take 8 instructions to do the counting:
    Code ( (Unknown Language)):
    1.
    2. X=200
    3. Y=210
    4. Z=220
    5.
    6. a:
    7. decrease X
    8. if X!=0 jmp a
    9. X=200
    10.
    11. decrease Y
    12. if Y!=0 jmp a
    13. Y=210
    14.
    15. decrease Z
    16. if Z!=0 jmp a
    17.
    18. this will take 200*210*220=9,240,000 ticks to get here, which should be
    19. more than enough even if your processor runs at 10MHz which I doubt
