I wish to build a glove that recognizes when my (specifically my four) fingers are in certain positions. I need some sort of sensor that will identify when adjacent fingers are close together. I want a sensor (block) along sides of the fingers between each knuckle. So two on the inside of the pointer, the middle and ring would have two sensors per side, and the pinkie would have two more on the side that rests against the ring finger. I'd also like to be able to differentiate between left and right hands, so that I can tell if the right middle finger is pressed against the right pointer, or left pointer (or any finger on the left hand, I don't need this to be specific), or if the fingers are spread and there is no contact.
Any suggestions as to a type of sensor that matches my description? I need to know if I am pressed against one of two possible contacts or apart.
I've tried to do some googling, but I have not had luck with finding good keywords. I've found a glove that the designers say can translate sign language, but the parts I can read about the glove refer to sensors that are inherently more sophisticated than what I need.
Thanks!
Thanks!
