Hi
Currently at university at the moment in first year and been told as a project I must design a and build a frequency meter.
"you are required to design and build a circuit to display the frequency of a TTL compatible square wave wave. Frequency meters consist of a counter, a display and a gate that is opened and closed under the control of an accurate oscoscillator, plus some control. Your circuit should consist of three seven segment displays and indicate frequency in the range of 0-999hz. Your circuit should freeze the display when the gate closes so that it can be read, and reset it to zero before the gate opens again. It will therefore be necessary to design some gate and reset control circuitry, and possibly latch"
Above is the exact brief given.
I'm unsure where to start at the moment my lecturer has only taught us about gates so far.
So any help being that of youtube videos or websites to read to help me understand to design and build this would be great.
Many thanks
Rhys
Many thanks
Rhys
