Building a discrete multi-stage guitar amp
Discussion in 'The Projects Forum' started by blah2222, Sep 23, 2012.
  1. blah2222
    May 3, 2010
    565
    33
    ***UPDATE***
    Three great articles on discrete JFET preamp design:
    - J201 preamp by Don Tillman
    - MPF102 preamp by James Hawes (adaption of Tillman preamp)
    - MPF102 preamp by Mike Martell
    Hey, I am getting back into guitar and have wanted to put some of my EE design juices together and would like to build a guitar amp out of a couple 2n3904s.
    I was thinking maybe two gain stages and then a buffer to match the speaker impedance.
    The datasheet claims that they can source a max collector current of 200mA which I think would be well beyond what I need to power a small 4ohm 1 W speaker.
    I'll just have to play around with filters to get rid of nasty harmonics and what-not.
    I'm not expecting Marshall-worthy sounds, but just a decent project to work on. Sound realistic?
  2. wayneh
    Sep 9, 2010
    12,399
    3,246
    I don't know about you, but something I've always wanted was a small practice amp - battery power capable - into which I could mix an iPod and my guitar, and output to headphones or a small speaker. That way, I could listen to and work on learning tunes without bothering anybody nearby OR take off the headphones and just have a nice little amp. Neat, self contained, rugged.
    Oh, and cheap! ;)
  3. blah2222
    May 3, 2010
    565
    33
    Like the AmPlug by Vox?
  4. t06afre
    May 11, 2009
    5,939
    1,222
    I would have used opamps no doubt about that. The will still put some of your EE design juices together. And the sound will be better. However if you still want to follow the transistor path. Take a look here http://forum.allaboutcircuits.com/showthread.php?t=73412
    In some of the designs. You may not be able to find the transistors used. But we may help you in finding equivalent models
  5. MrChips
    Oct 2, 2009
    12,648
    3,459
    You will be very disappointed with a couple of 2N3904s.
    I have already built a guitar amp, but not with a small 1W speaker.
    I used a couple of TL071, a bridged car audio amp, driving a 450W 12" speaker, powered from a 12V SLAB.
    I can use this to play guitar and bass anywhere I go, practice at home, in the garden, on the beach, around the campfire with enough audio power to play on a gig. Unplugged.
  6. Dodgydave
    Jun 22, 2012
    5,166
    775
  7. tracecom
    Apr 16, 2010
    3,879
    1,396
    Think about a JFET (MPF102) and an LM386: cheap, simple, sounds good, runs off 9V.
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    Didn't you do the simple calculation for the peak current?
    1W into 4 ohms is (the root of 1 x 4, x 1.414=) 2.83V peak. Then the peak current is (2.83V/4 ohms=) 708mA which will blow up the tiny 2N3904 transistors.
    Amplifiers usually use a class-AB output stage that has a pair of complementary power transistors as emitter-followers, driven by a voltage-amplifying stage.
    Your design has a class-A output transistor as a heater instead of as an amplifier.
    A little LM386 amplifier with a 9V supply has an output of only 0.4W at clipping into 4 ohms and the IC gets very hot.
  9. tracecom
    Apr 16, 2010
    3,879
    1,396
    I built the attached amp to play my MP3 player through a speaker, and I use it regularly into a 4Ω speaker. The audio quality is good enough for my purpose if I limit the drive to keep the output at 3.6 Vpp or less. The volume is loud enough for my somewhat diminished hearing. The IC is not even warm to the touch.
    There are certainly better amplifier IC's than the LM386, but it works for some purposes. There are lots of videos on youtube of people using a guitar amp called a "ruby amp" that uses a MPF102 and an LM386.
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    An LM386 amplifier with a 9V regulated supply and a 4 ohm speaker has an output (with horrible distortion) of 0.4W and it heats with 0.9W if it has lots of sustain for almost continuous full output power.
    An LM386 works best with an 8 ohm speaker. Its output with a 9V regulated supply is 0.56W when clipping a little and is 0.45W with low distortion. It heats with 0.53W if it has lots of sustain for almost continuous full output power.
    A little 9V "transistor" battery will croak and die quickly when powering the amp driving a 4 ohm speaker when the peak current is 450mA.
    Which gets hotter, the little amp or the little battery?
    I don't have a graph of a little 9V battery being shorted with 450mA but here is 400mA:
  11. tracecom
    Apr 16, 2010
    3,879
    1,396
    I respect your opinion and don't have the expertise (or the inclination) to argue with your data. I am simply stating my real world experience after having built the amplifier and used it on a regular basis for the last several months. Neither the amplifier nor the battery has ever gotten hot, and I have used only two batteries during the entire time period; the second one is still in use.
  12. wayneh
    Sep 9, 2010
    12,399
    3,246
    Pretty much, yes. I'd also like a small built-in speaker so I wouldn't always have to wear headphones. You'd need more battery for the larger amp, but I could live with that. Oh, and cheaper!
  13. MrChips
    Oct 2, 2009
    12,648
    3,459
    A JFET and an LM386 running off a 9V battery is worth trying.
    I would go with an 8Ω speaker instead of 4Ω.
    I'm going to breadboard this and report back.
  14. tracecom
    Apr 16, 2010
    3,879
    1,396
    Please do. I have (solderless) breadboarded it and liked what I got so much that I have laid out a PCB, but not yet ordered. I am very interested in your design and results.
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    Then the amplifier is playing at a low output level.
  16. wayneh
    Sep 9, 2010
    12,399
    3,246
    I just bought a TLV272IP (dual rail-to-rail op-amp) for my parts pile. Could that be used in place of the JFET stage?
    A lot of those cheap "PC" speakers use a LM386. I have a bunch laying around and I've often thought of mounting a battery holder and pre-amp inside one. Instant practice amp. I could even leave the existing transformer in place for AC operation.
  17. Audioguru
    Dec 20, 2007
    9,411
    896
    Yes but it has a lot of hiss.
    A Jfet has very low hiss and needs only two resistors:
  18. MrChips
    Oct 2, 2009
    12,648
    3,459
    I have something similar so far. I will draw up the circuit after I get a chance to test it with a guitar.
    I am using a MPF102 in common-source configuration.
    (560Ω on source bypassed with 10μF. 1k8Ω on drain.)
    20mV input gives 2V into 10Ω load (have not tried speaker as yet).
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    You are making a Jfet preamp similar to this one but the resistor values are lower. With the source resistor bypassed then the total gain might be far too high:
  20. wayneh
    Sep 9, 2010
    12,399
    3,246
    Is the hiss level relevant to being used with a LM386 amp? I mean, those things aren't exactly hi fidelity. And neither is my hearing these days. ;)
