Building a digital tachometer
Discussion in 'The Projects Forum' started by jaysonphuan88, Mar 14, 2011.
  1. jaysonphuan88
    Apr 16, 2009
    Hey people,
    How do i build a digital tachometer using infrared transceiver and receiver to get an output of a varying voltage that feeds into an analog input of PIC? Do get back to me asap!
    Thanks!:cool:
  2. wayneh
    Sep 9, 2010
    12,374
    3,226
    You'll need what's known as a frequency-to-voltage converter. You can make one with a 555 timer circuit. You may need some signal conditioning to use the IR receiver to trigger the 555.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I'm not certain why you'd want to go that route.
    Instead, consider using a Hall-effect sensor near a gear or drilled hole or square/hex nut, backed up by a weak magnet. Hall-effect sensors are available in a wide variety of configurations. You'd want something like a single-phase switch, perhaps an AH337, or ATS137.
    Then tie the sensor output to an I/O pin, and have it trigger an interrupt to increment a counter.
    Have another counter keep track of the time. When this counter overflows, calculate what the frequency of the input from the Hall-effect sensor is, and from that determine the RPM.
  4. wayneh
    Sep 9, 2010
    12,374
    3,226
    Sarge is right. What's more important, making the tach or using the strategy you started with? If you want digital in the end, it's better to maintain the tach signal pulses as digital. No reason to convert to an analog voltage.
