So then, when you act like an expert, post inaccurate and misleading information, you want me to be silent?i dont take any notice of your posts, as you usually think you know all the answers, and Always like to think that!
Just shut up and listen to Mike. He is an qualified engineer that flies planes.Idont act like an expert, i am one,
I dont post anything thats wrong, just information and ideas from working circuits , the op wants to make a charger his way or another way.
A bit cryptic at times, but I suffer from that, too.Just shut up and listen to Mike. He is an qualified engineer that flies planes.
Well the way of the world is through qualifications, and Mike is probably the most qualified out of all of us. I have 1/3 of an B.SC degree in information technology, but it is only one third! Plus 2-years Tafe college back in 1997 for an trade in electronics (not design)A bit cryptic at times, but I suffer from that, too.
You can't label yourself an expert. It is up to others to decide if you are an expert or not..
you can button it too mate,
What Mike posted in #7 is textbook, and I would run for it with that.So, back on track...
The original sketch-up I posted (with the pot in place of R2)...good to go? Need a current-limiting resistor in series with the output? More comments? Other examples of schematics (the simpler the better)?
Mate I have reported your PMs to the moderators. Expect a ban, especially if I put some money on the table to have you removed.look at figure 56 on page 25 of datasheet, uses a npn current limiter transistor in the negative supply, use that method and select the resistor to suit the current limit you want.
I was looking at this yesterday. What is the value of R2 (the pot)? Is it 500Ω with the wiper set to about a midpoint (.42)? Is that how I should interpret the schematic?What about SgtWookie's circuit (http://forum.allaboutcircuits.com/attachments/bill-sla-float-charger-temp-compensated-png.21844/) from 2007?
Has anybody put together a better 12V float charger since that one?
The laptop brick I have for a supply is 19.5 V @ 4.7 A. I'm assuming this supply would be appropriate for the circuit you posted? Its parameters are OK? Would I need to change any components?Yes, R2 is a 500 Ohm trim pot set approximately halfway.
The circuit is OK for maintaining a floating voltage on a SLA, VRLA or AGM 12v battery.
There are multiple lead-acid charge controller ICs on the market, but I'd be more likely to design a charger using a microcontroller with a switching supply.
I've been reading a lot of your old posts on this topic, and had been planning on building that circuit. But in an earlier discussion, you mentioned that this circuit was a "lowest common denominator", and that there are better options available. And now you're suggesting a different solution.Yes, R2 is a 500 Ohm trim pot set approximately halfway.
…The LM317 has a rather large dropout voltage (minimum voltage difference between the input and the output) so that the power dissipation is higher than more modern regulators, but the more modern regulators may have stability issues, requiring careful selection of output capacitors.
There are linear ICs available specifically for lead-acid battery maintenance which provide more advanced features (bulk charging and equalization in addition to topping charge and float charge) and digital versions which can result in higher efficiency at the cost of somewhat additional complexity, along with programming requirements. Switching supplies can be tough for beginners, as you really need at least an oscilloscope to troubleshoot them; and very few start off with a bench full of test equipment and know how to use them.
If your battery is 9 years old, it's survived probably twice as long as most people's car batteries. I get 6 or 7 years out of them, but after a certain point it's not worth the trouble/inconvenience caused by having a vehicle that is not reliable. I live way out in the boonies; the nearest gas station is a 20-minute drive.
Lead-acid battery capacity is affected by the internal (core) temperature; as the temperature increases, chemical activity increases, and so does battery capacity; conversely, the "fully charged voltage" decreases - that is why temperature compensation is important. Continually overcharging a lead-acid battery will shorten it's service life. However, periodic "equalization charging" will stir the electrolyte and help remove sulphation from the plates. Equalization charging is basically a brief repeat of the "bulk charge" phase, but on a periodic basis.
While increasing the core temp increases the battery capacity, it decreases the service life due to the increased chemical activity.
Here: Battery %Charge Vs Core Temperature
As you can see on the chart, when the core temp drops to about 20°F, your battery capacity is decreased by nearly 1/3 - and your battery is ancient to begin with. If you're determined to keep using that battery, then you need to figure out how to keep it warm during the cold periods, and keep it float charged.
There are also "desulfator" circuits, which I've used with some successes, having revived a few riding lawnmower batteries that were ready for the salvage yard. I've posted one or more of these circuits on here; Alistair Cooper (sp?) came up with the idea originally a number of years ago. The version I made used an N-channel MOSFET instead of a P-channel, still 555 timer based; and had provisions for float charging while desulfating.
While the equalization charge would remove the plate sulfation in a much more rapid manner, it will also increase the core temperature of the battery. A battery with the core temperature at 55°c has 1/3 the service life of a battery with a core temp of 25°c. A desulfator won't significantly change the battery core temp.
Here's an application note on a lead-acid charger using a Microchip PIC16HV785:
http://ww1.microchip.com/downloads/en/AppNotes/01015a.pdf
Digikey stocks that PIC: http://www.digikey.com/product-detail/en/PIC16HV785-I/SS/PIC16HV785-I/SS-ND/1098727
but that's in a SSOP package, which would be difficult for a new hobbyist to use. They ARE available in DIP and SOIC packages.
Sorry Ray. I didn't mean to interrupt. Does anybody have an answer to this question that may have been overlooked due to my posting immediately after it?The laptop brick I have for a supply is 19.5 V @ 4.7 A. I'm assuming this supply would be appropriate for the circuit you posted? Its parameters are OK? Would I need to change any components?
I think somewhere in the thread it was said (or maybe implied?) that laptop bricks like mine OK for this application. Suitable current range (though way more than the LM 317 can handle!), enough voltage potential to cover the LM 317's drop, and some room to spare (hence the 500 Ω trimmer pot). I'll be working on the circuit that Sgt. Wookie posted for the next couple of months (can only do it in my spare time) as well.Sorry Ray. I didn't mean to interrupt. Does anybody have an answer to this question that may have been overlooked due to my posting immediately after it?
