The circuit in Figure 53 should work for you with the output set to about 13.8V as #12 suggested.
Rs is only needed if you want to limit the maximum current below the LM317 internal limit. As the battery voltage reaches 13.8V the current will reduce to whatever trickle-charge level is needed to maintain 13.8V.
The LM317 will handle the limit current as long as it's on a good heat-sink. If it does overheat it will automatically reduce the current limit value to prevent destruction of itself, but it's not good (from a reliability point of view) to operate for a long time period under such thermal limited conditions.
Note that you should add the recommended input and output capacitors to the LM317 to insure stability.
