No relay? I assume you are concerned about the mechanical life? There is such a thing as a solid state relay, which I think could be useful here.Thank you for your input.Being more specific,I wish to build or find a simple thermostat circuit which could handle a two dozen chicken egg incubator .the incubator will use an electric globe as a heat source and will have a 12 volt fan for air circulation.Preferably no relay in the circuit.
The optimum temperature for forced air chicken egg incubators is 99.5° F.Does the temperature need to be adjustable? If not, what temperature do you need?
So, it must have some sort of power adaptor on board, like a transformer maybe?It has a 12 v fan for air circulation and egg turning is done manually.
Interesting IC - it sounds like a good choice for this application. Do you just need an application circuit example, or is there a reason you're not just using that circuit that you've used before?Hi Wayneh,
Thanks for your interest.Well ,it it needs be that a small transformer is used so be it . However, last year I was using a 240v ac incubator circuit which was very simple.It was a wesfan circuit and it worked on straight 240v ac current.All it had on board was six components.The chip (ca3059) seemed to be doing all the work.
Where are you? I see many sources after a quick Google search. For example: http://store.americanmicrosemiconductor.com/ca3059.html?gclid=CI727vnEiqcCFQTrKgodXySGdwHi Wayneh,
Thanks for your reply. I cannot get the CA3059 locally and to get it from Asia ,where it is readily available,the cost is something like 10 times the cost of the chip.
