Building 24VAC to 12VDC power supply
Discussion in 'The Projects Forum' started by faf79, Jul 12, 2014.
  1. faf79
    Jul 12, 2014
    Hello forum members
    I'm working on arduino project and I need to make small and efficient power supply for the arduino microcontroller.
    The only power source I have is 24VAC line, I would like to use that line to convert the AC to DC and then step down to 12V via regulator.
    I'm adding the electric schematic that I made for the power supply.
    I have few question to ask you because I'm still new to all this subject.
    1. I need help to determine which fuse value should I put in the system - if my regulator output is 12V 1.5A (MAX) should i put 1.5A ? (The reason I'm putting a fuse is because if something went wrong I need it to burn the fuse instead of burning my home)
    2. I need help to determine the value of the c2 and c3 in my system, I researched a lot on google and found few people that did similar projects and each one of them used different capacitor values, then I tried to look for how to calculate which cap value do i need and i didn't found something that would be clear and understandable enough for me.
    3. If you see something wrong with my schematic it would be great if you could tell me about it, also suggestions for improvements are always welcome :)
    Thank you very much for your help
    John
  2. shteii01
    Feb 19, 2010
    3,500
    511
  3. shteii01
    Feb 19, 2010
    3,500
    511
    The fuse is on the ac side. So the part you need to worry about is the bridge. How much current can the bridge take?
  4. shteii01
    Feb 19, 2010
    3,500
    511
  5. shteii01
    Feb 19, 2010
    3,500
    511
  6. NorthGuy
    Jun 28, 2014
    611
    121
    Not a good idea.
    24VAC is 34V peak. Assume you undersize your capacitor a bit and get 30VDC. You want 12V. This means that 18V will have to drop on 7812. At 1.5A, it's 18x1.5 = 27W. I don't think 7812 can take this, even with a huge heat sink.
    You need a switching regulator or a transformer.
  7. ronv
    Nov 12, 2008
    3,393
    1,454
    We either need some more numbers or we can make some assumptions. Lets assume. :)
    Your input voltage is kind of high. 24 volts RMS turns into almost 34 volts once it charges up the filter cap to the peak voltage, so I'm going to pick 1/4 amp for the maximum output of the supply. What this means is your regulator needs to dissipate around 5.5 watts ( the difference between 34 and 12 X .250) so you need a heat sink for it. So now to your question for the caps. Take a look here so you can see how things look.
    http://www.radio-electronics.com/in...er-filtering-smoothing-capacitor-circuits.php
    So using their formula and solving for say 17 volts (5 volts above the regulated voltage) we need maximum ripple of about 17 volts since we loose a little voltage across the diodes and the regulator. We would get about 120 ufd. So use 150 and the ripple will be around 14 volts.
    For the other capacitor just use the one recommended in the data sheet. 0.1 ufd. I think.
  8. faf79
    Jul 12, 2014
    That's why I want to make one.. (and also because I want to learn)
    The bridge is build from 4 LN4007 Diodes so by the datasheet I assume it's 30A ?
    www.diodes.com/datasheets/ds28002.pdf
    You're right, I will fix it, thanks.
    I saw that, I need to know why they choose those and how can I calculate it by myself.
    You're right, it cannot do that, I took your advice and I will change it to switching regulator.
    I found one that based on LM2575 - DATASHEET: http://www.ti.com/product/lm2575
    Here: http://www.ebay.com/itm/3-Terminal-12V-1A-Switching-Voltage-Regulator-Power-Sup-/400079060937?pt=LH_DefaultDomain_0&hash=item5d2691ffc9
    It's already assembled in a way that i have 3 pins just like the LM7812.
    Regarding the regulator I will change it to switching regulator since it won't stand the hit.
    The switching regulator will be LM2575 - DATASHEET: http://www.ti.com/product/lm2575
    So from what you say I need to put 330uF cap after the bridge and 0.1uF after the regulator?
    Also, the one that is located after the bridge should be 50V? 24V rms will be 34V so 50V is safe enough?
    and the one after the regulator should be around 24V ? double of the 12V regulator input
    Thanks guys for the quick answers :)
  9. NorthGuy
    Jun 28, 2014
    611
    121
