Building 2 Axis inclinometer
Discussion in 'The Projects Forum' started by Rahul Shah, Feb 12, 2016.
  1. Rahul Shah
    Nov 4, 2014
    5
    Hi All,
    I am in process of building 2-Axis Inclinometer. Ideally a 2 or 3 axis mems accelerometer along with a mems gyroscope should solve the problem. There are 6 axis solutions available from ST, Invensense and others with digital interface to host controller. All costing nearly about 5-6 USD max. In their application they do not mention that this can be used as +/- 90 deg inclinometer. I need resolution up to 0.001 deg.
    Yet, I came across a product from Analog Devices - ADIS16201. This product claims that it can be used as +/- 90 deg inclinometer. This is also a 2 axis accelerometer but costing around 30 USD!!!! I compared the specs and almost all are same.
    Why is this price difference? What should I go for? A cheaper solution or a costlier solution like Analog Devices?
    Thank you,
    Regards
    Rahul Shah
  2. Sensacell
    Jun 19, 2012
    1,184
    277
    Devil is in the details- remember that specs are written by MARKETING PEOPLE to sell parts!
    You really have to dig-in and study the parts in detail to see how things add up.
    "Show me a simple answer and I'll show you a poorly considered question"
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    From the ADIS16201 datasheet:
    Even at $30 it doesn't come close to what I think you mean by "resolution." That is, the LSB has some meaning. 0.001° resolution for 90° will require 2^17 "resolution."
    Of course, if all you want is resolution, not accuracy or precision, then that is a different story.
    John
