Builder/Compiler contrast
Discussion in 'Programmer's Corner' started by nanobyte, Aug 17, 2007.
  1. nanobyte
    Thread Starter Senior Member
    May 26, 2004
    118
    What is the difference between a builder and compiler in software?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The compiler parses a series of declarations and outputs machine-level code for execution. I may be showing my age, but I have never hears of a builder function. Is it perhaps some kind of MS flim-flam associated with .NET stuff?
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I've only ever heard of the term 'builder' in the C++ world. AFAIK, it just refers to a general software development environment that has all the tools a software developer would require. Based on this assessment, I suppose the main difference is that builders are high-level development tools and compilers are low-level development tools.
    Dave
  4. Eduard Munteanu
    Sep 1, 2007
    86
    Yes, a builder is more than a compiler. One usually says "build the project". Builders deal with projects, i.e. collections of source code, rules (which tell how to build the target), docs and so on.
    An example that shows the difference comes from the Linux world: (Auto)make (builder) vs. GCC (compiler). When you issue 'make' and 'make install', the builder parses the rules and calls the compiler to transform source code into executables. It does even more: it builds the documentation (possibly by calling TeX, which is just another compiler, apart from the fact that it does not create executable code, but PDFs for example) and it may install the application.
    Shortly, the builder automates the process of compiling, installing etc..
