Build two linear power supplies.
Discussion in 'The Projects Forum' started by ScottWang, Apr 15, 2013.
  1. ScottWang
    Thread Starter Moderator
    Aug 23, 2012
    4,934
    777
    Hi Dear All:
    I want to build two new linear power supplies, now I already have the power supplies as below:
    1 0~50V/ 2A/4A Linear Regulated Adjustale dual polarity Power Supply
    With output short-circuit protection using relay.
    Base on LM723 and two 2N3055.
    This is a kit that I bought it long time ago, so I have the circuit diagram.
    2. Fiive Fixed Voltages Linear Regulated dual polarity power supply.
    The three fixed voltages that they are series in as ±15V → ±12V → ±9V.
    a) ±15V -- Using 7815,7915.
    b) ±12V -- Using 7812,7912.
    c) ±10V -- Using Six 1N4007. (connected from ±12V).
    d) ±9V --- Using 7809,7909.
    e) ±5V --- Using 7805,7905. (this transformer is stand alone)
    I bought the two transformers as below:
    1. PT-47 (Made in Taiwan)
    Input : AC 110V
    output :
    AC 24V,0,24V ------------ 0.6A
    AC 0,6V,11V ------------- 2A
    AC 42v,36v,0,36v,42v -- 6A
    AC 0,24V ----------------- 1A
    2. Another Transformer (no type number) --
    Input : AC 110V
    Output:
    0,12v ------- 1A
    0,12v ------- 2A
    42V,0,42V -- 5A
    24V,0,24V -- 2A
    The functions of the new power supplies:
    1. Linear regulated dual polarity power supply.
    2. Dual tracking.
    3. Temperature detection and loopback current control.
    4. output short-circuit protection.
    5. 12bits ADC 7-segments LED Voltage and Current Display
    6. USB communication System - Using AT89S52 Can be communicate with computer.
    7. LM317 & LM337 Base with 2N3055 And 2N2955 or MOSFET.
    8. Adding some other functions or using other regular IC.
    I am open my mind to hear any suggestions from you guys.
    Thank you.
  2. atferrari
    Jan 6, 2004
    2,674
    785
    Is it necessary to have it hanging from a PC?
  3. #12
    Nov 30, 2010
    16,705
    7,358
    When I did the five fixed voltages, I used the L versions because 100ma is more than enough to run most of my experiments, and they smoke less when my mistakes are limited to 100ma.
    Do not try to get more than 3 or 4 amps out of a 2N3055. You will have massive heat problems, even at that level.
  4. ScottWang
    Aug 23, 2012
    4,934
    777
    Because I already have some independent power supply, the new power is designed for the new measuring experiment.
    I bought a multimeter UT61E, it has Rs232 function, but the capture time is auto setup by the program, the maker didn't announce the control method, they just send the software to run it between the multimeter and computer, so I can't design the software by myself, if I want to design the software by myself that I have to spend more time to figure out how they communicate.
  5. ScottWang
    Aug 23, 2012
    4,934
    777
    Thanks.
    The circuit that I got it when I buy the kits, the original design that the 2N3055 is designed for 2A, so I keep it in my mind, two 2N3055 just for 4A, one 2N3055 for 2A.
    I would like to using MOSFET to place the 2N3055, but I'm not figure out the good method yet.
  6. #12
    Nov 30, 2010
    16,705
    7,358
    It doesn't seem hard from here. Mosfets just use more voltage and less current to run their gates.
  7. ScottWang
    Aug 23, 2012
    4,934
    777
    Yes, maybe that is not so hard, but I have to try it in the amplifier area, I can't treat it like a switch now.
  8. #12
    Nov 30, 2010
    16,705
    7,358
    When you can post the schematic, we will check it for proper analog operation using mosfets.
  9. ScottWang
    Aug 23, 2012
    4,934
    777
    I'm not draw the circuit yet, because I would like to hear the suggestions, maybe that can give me some new ideas.
  10. #12
    Nov 30, 2010
    16,705
    7,358
    I don't know. Power supplies are about as old as Edison.
    On the other hand, I like to include an adjustable constant current source, or switchable...1ma, 10ma, 100ma.
  11. ScottWang
    Aug 23, 2012
    4,934
    777
    Thanks.
    The transforemer has some secondary coils, maybe I can use them for different current.
    I have been design a simple adjustable current of the power, but I haven't design the adjustable constant current source yet, switchable...1ma, 10ma, this is useful and easy to do.
  12. t06afre
    May 11, 2009
    5,939
    1,222
    Huh that sounds more like a design order than a request for help:confused:
  13. ScottWang
    Aug 23, 2012
    4,934
    777
    Ha ha, that would be my toy not the order from customer.
    I just want to know that how to using two transformers to get more useful functions.
