build Measure capacitances
Discussion in 'General Electronics Chat' started by pini200, Feb 15, 2016.
  1. pini200
    Feb 15, 2016
    14
    hello
    I need to build device that Measure capacitances
    the range of capacitance is 50nF-300nF
    What's the best way to achieve accuracy
    (I think use in 555 and how i build this )
    thanks
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    There are many ways to do this. Three examples:
    You can apply a calibrated DC voltage or current step and measure the rise time of an R-C network.
    You can put the capacitor in an oscillator circuit and measure the frequency.
    You can apply a sinewave through a resistor and measure the attenuation caused by the capacitor.
    ak
  3. wayneh
    Sep 9, 2010
    12,374
    3,225
    A 555 circuit can be used, but you need to think about what precision and accuracy you need. (These are not the same - consider both.) A 555 is not nearly as precise as a crystal oscillator and will limit the quality of your results. Depending on what you are doing, it may be fine.
  4. #12
    Nov 30, 2010
    16,665
    7,313
    Trim pots. Include adjustment potentiometers so you can calibrate to something well known.
  5. pini200
    Feb 15, 2016
    14
