Build error problem with c++ file
Discussion in 'Embedded Systems and Microcontrollers' started by hunterage2000, May 28, 2015.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    I am trying to clean and build the attached .cpp file but I am getting errors which I don't understand. I have created a c++ main file in MPLAB but it is seeing errors with:
    #include <cstdlib> which is supposed to be the same as <stdlib.h>
    and
    using namespace std;
    Can anyone help?
  2. kubeek
    Sep 20, 2005
    4,688
    806
    don´t you have to state the namespace before you include the libraries?
  3. hunterage2000
    May 2, 2010
    402
    Not sure. When I create a new C main file the code shows:
    Code (Text):
    1. #include <stdio.h>
    2. #include <stdlib.h>
    3.
    4. int main(int argc, char** argv) {
    5.
    6.     return (EXIT_SUCCESS);
    7. }
    When you clean and build it as it is there is no problems but when I create a C++ file and do the same it gives errors for the #include <cstdlib> and using namespace std.
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    I was a little curious so I downloaded the XC32++ compiler, created a dummy project a and main cpp file. The default main cpp gave me the exact code you posted.
    And then it built just fine with no changes.
    Code (Text):
    1. /*
    2. * File:   newmain.cpp
    3. * Author: ErnieM
    4. *
    5. * Created on May 31, 2015, 8:18 AM
    6. */
    7.
    8. #include <cstdlib>
    9.
    10. using namespace std;
    11.
    12. /*
    13. *
    14. */
    15. int main(int argc, char** argv) {
    16.
    17.     return 0;
    18. }
    19.
    20.
  5. DumboFixer
    Feb 10, 2009
    219
    34
    Looking at the output you have the following:
    Code (Text):
    1.
    2. make[2]: *** No rule to make target 'build/default/production/neimain.o', needed by 1dist/default/production/Blink_pin.X.production.hex'. Stop,
    3. make[1J: *** [.build-conf] Error 2
    4. make: *** I.build-implJ Brror 2
    5.
    To me that says you have something wrong with your makefile as it doesn't know how to make neimain.o
  6. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Did you first create a cpp project, or just a main.cpp?
    You need the project to set up the make file.
  7. hunterage2000
    May 2, 2010
    402
    When you create a new project there is no option to choose the type. You just add new file to the project in the project window. I am using xc8 compiler, maybe you can't use c++ with it or you might have to edit the makefile. Not sure.
  8. ErnieM
    Apr 24, 2011
    7,436
    1,625
    I'm sure. Use the menu and click File | New Project and follow the wizard.
    When you get to Select Compiler check the version that supports C++. That's xc32 v 1.34 on my computer.
  9. hunterage2000
    May 2, 2010
    402
    It looks like only the PIC32 family can use C++.
