KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
Easy to get confused.
The red LED requires 5.1V and the green LED requires 6.6v to turn on so the 6V from your 4 batteries is not sufficient, you need at least 5 batteries...........
I need help with selection of parts. Can you all please look at the ckt and let me know ? Does this work with the parts I selected?
Yes, DesignSpark does the conversion for you to a .GBR file along with drill files. There are lots of different options, just hoping I have them all correct..Most PCB houses require Gerber file format. I am not familiar with DesignSpark; can they export to Gerber format? I use DipTrace and Oshpark to make my PCBs. It's as simple as uploading a zip file with the Gerber files and paying!
If you look at the PCB vendor websites they should be able to help you decide among the various options.Yes, DesignSpark does the conversion for you to a .GBR file along with drill files. There are lots of different options, just hoping I have them all correct..
Thanks.If you look at the PCB vendor websites they should be able to help you decide among the various options.
You can do a single-sided board using a double sided process..................Does anyone have any recommendations for a manufacturer? Most seem to only want to do double sided boards and mine is single sided.
Didn't mean to imply that.So its better to do all my traces on the top layer? For some reason I thought all traces on the bottom would have been easier. Thanks for the heads up!
