Build a DPDT Switch
Discussion in 'The Projects Forum' started by nicmon, Mar 19, 2011.
  1. nicmon
    Mar 18, 2011
    30
    I can't find a Push Button which acts as a DPDT Switch, I want to use it to build an Eject button for a DVD-Drive. it works in the way that the Drive have a current of 3.3V in whole time and once we disconnect the wire from 3.3V and connect it to GND shortly and put it back to 3.3V, the Drive will be ejected.
    a quick solution would be use a slider for that.
    my question is, is it possible to use a Push Button combined with a Transistor to invert the current and build such a circuit?
  2. Bernard
    Aug 7, 2008
    4,240
    414
    If you can add resistance between 3.3V & drive without disturbing normal operation, then a SP ST NO push button connected between drive & ground should work. Resistance should be high enough to not effect 3.3V & low enough not to bother drive.
  3. Kermit2
    Feb 5, 2010
    3,851
    966
  4. nicmon
    Mar 18, 2011
    30
    wow that's very big, I have ordered one once before, they don't match into a normal circuit.
    sounds like a very good solution, do have an idea about the value of that resistance?
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
  6. Bernard
    Aug 7, 2008
    4,240
    414
    sounds like a very good solution, do have an idea about the value of that resistance?[/QUOTE]
    Assuming that the 3.3V is a power supply, it should support a current of 50 mA, so I would try 68 Ω to 100Ω. Why the requirement for a double pole SW?
  7. nicmon
    Mar 18, 2011
    30
    Sorry, I meant actually a Single Pole (SPDT) Switch.
    I'm using a normal PC Power Supply and a LM1086 Voltage Regulator to reduce the 5V from Power Supply to 3.3V.
    I put 2 100K Resistors between the Drive Wire and Ground and it worked, but the problem ist that Voltage Regulator becomes very hot after pressing the Switch, so it seems that I still need some changes.
    hier is a simple version of my circuit, the RED Wire is which I'm trying to connect to Ground via Push button:
  8. Kermit2
    Feb 5, 2010
    3,851
    966
  9. Bernard
    Aug 7, 2008
    4,240
    414
    'Not sure where you put resestor & PB SW. This is what I was thinking.
    nicmon likes this.
  10. nicmon
    Mar 18, 2011
    30
    Yes, that worked, really appreciate for your help.
