Bug zappers, source(s) for replacement HV transformers
Discussion in 'General Electronics Chat' started by Dwayne Oxford, Jun 19, 2016.
  1. Dwayne Oxford
    Mar 22, 2015
    18
    Anybody know of any?
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    Buy another bug zapper, take out the transformer :)
    Ok seriously though this is a good question. Sorry i dont know of any offhand but i am sure someone here does. Back long ago myself and some fellow workers made a bug zapper out of a old TV high voltage transformer, but they are probably expensive to buy new.
    Dwayne Oxford likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    What about trying to adapt an old auto H.V. coil from a wrecker?
    Max.
  4. Dwayne Oxford
    Mar 22, 2015
    18
    Wrecker?
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Automotive scrap yard.
    Max.
  6. MrAl
    Jun 17, 2014
    2,556
    515
    Yeah i was going to say from an OLD TV set, but we dont see as many CRT type TV's around anymore. Old ignition coil might work.
  7. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    Long back ago, I tested Bug zappers with Q-tip.
  8. Dwayne Oxford
    Mar 22, 2015
    18
    Yep,I do too.
    LOL, Here, a wrecker is a tow truck. I've got 11 "parts" vehicles. Guess a 120VAC-12VDC transformer and 12V coil might work. I've got both, worth a shot anyway. Thanx!
  9. Dodgydave
    Jun 22, 2012
    5,154
    772
    Just put the 12v ac from your transformer to the ht coil, that will work on 50/60 hz.
  10. ACvoltage
    Jun 20, 2016
    If you have an old microwave lying around, all microwave ovens contain a 2-5kV step-up transformer inside. This is because mangetrons--the units that generate the microwaves--require high voltage. Though, I'd be careful if you decide to go that route because they operate at high current. But back to your bugzapper, I was able to construct a functional bug-zapping device out of a high pressure sodium lamp and 2 wire-mesh screens only running off 120 volt mains.
