Hi, I read through the bug zapper posts and didn't find the info I need. The lights stopped working in my bug zapper after many years. When I removed them I found the glue that holds the pins on had come loose from the glass. This old thing isn't worth $30 of new bulbs relying on this old circuit board and ballast to give them life. I thought it would a good idea to remove the florescent lights and update it with uv leds. When I took the top off I found the hv transformer wired in with the florescent bulbs and this hi-tech circuit board. I would like to use this hv transformer without the circuit board and florescent light circuit. My question is can I wire the primary of this transformer 120v? Possibly with a small bulb or resistor in series and if so what size resistor or watt bulb. I have tried to attach a photo.
If I can get the hv transformer working then I can install the led light circuit and add a photo cell and be back on the road again better than before.
Any thoughts?
Thanks in advance
Rob
Any thoughts?
Thanks in advance
Rob
