Bug zapper project help
Discussion in 'The Projects Forum' started by TwistedX04, Oct 15, 2016.
  1. TwistedX04
    Jul 9, 2016
    ive seen bug zapper projects and diagrams but nothing where the power source is household electricity. Can anyone help me out and show me a diagram/parts list that would use 110v household as the power source?
  2. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    The User Agreement will not allow direct mains powerd circuits.
    Try to find a circuit that is based on a 12 Volts powersupply.
    Bertus
  3. TwistedX04
    Jul 9, 2016
    I was unaware of that, do you know of a place I could go and ask for this? My project is something that is based on 110v
  4. Colin55
    Member
    Aug 27, 2015
    204
    21
    There are hundreds of 110v bug zapper circuits on the web.
  5. Dodgydave
    Jun 22, 2012
    5,152
    770
  6. tcmtech
    Nov 4, 2013
    2,111
    1,751
    A common Hv neon sign transformer is all you need to produce the 3 - 4 Kv but I don't see the point of building one when you can buy a bug zapper that will actually work for way less than you will build one.
    Especially now that it's the fall season and many places are selling off their summer stock units for $20 - $30 Vs their regular $50 - $80+ summer prices.:rolleyes:
  7. TwistedX04
    Jul 9, 2016
    Because it's not going to be your standard bug zapper
  8. Bernard
    Aug 7, 2008
    4,240
    414
    As a start use a 5.5 kV neg. ion generator, 12 V DC input, Electronic Goldmine # G 21544, & a 12V SMPS.
    Space grid wires far enough so that there is no continuous arc, maybe around 5 mm, or reduce input V.
  9. tcmtech
    Nov 4, 2013
    2,111
    1,751
    Meaning?
    If its 12 volt DC powered obviously it won't pack the bug burning power a common NST will put out leaving you with crappier one than had you bought a good factory made unit. :rolleyes:
  10. TwistedX04
    Jul 9, 2016
    Meaning I want to be able to plug this into the wall and pull the 110v off the wall to power it but there aren't many diagrams that use components rated for 110v so I asked for help here
  11. tcmtech
    Nov 4, 2013
    2,111
    1,751
    See post 6 and Google search as needed.
    If it's smaller than your thumb and has 6 or more legs a 30 mA lower voltage neon sign transformer will kill it. ;)
    Plus being a common iron core line voltage powered device it is well within the allowable terms of the site.
    (Just don't say your going to put an LED on it or the will mods go money poop over that and shut down the thread. LED on mains power here is seen as atomic radiation level deadly) :rolleyes:
