Buffered Band-pass
Discussion in 'General Electronics Chat' started by Shagas, Sep 17, 2013.
  1. Shagas
    Thread Starter Active Member
    May 13, 2013
    802
    74
    Hello ,
    I want to make an adjustable bandpass filter for a 0-5volt audio signal.
    The low-pass will be adjustable from about 30-200hz and the high pass from about 1000-5000hz.
    I'm planning to do something like this
    http://www.electronics-tutorials.ws/filter/filter_4.html
    But i'm planning to add a unity gain op amp buffer(powered by 9v) between the two stages and on the output aswell so In total two buffers.
    Two pots will be adjusting the bandpass frequencies .
    I've calculated my high pass to be 100nf and 5k-50k variable resistance and for the low pass 22nf and 1k-10k variable resistance.
    What do you guys think? Is it necessary to put a buffer inbetween the stages and on the output or would it be enough to have one in between.
    The output is going to drive the wiper of a 50k pot which will go to a micro ADC.
    Metalmann likes this.
  2. ronv
    Nov 12, 2008
    3,393
    1,449
    I would buffer both of them. Then you don't need to worry about what the input to the ADC looks like.
  3. Shagas
    May 13, 2013
    802
    74
    Ok thanks for the advice, ronv
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    You can using CD4066 to be the AC signal switch, to select several different bandpass filters.
    Also the CD4051 is another choice.
  5. Shagas
    May 13, 2013
    802
    74
    yes thanks that's a good idea
  6. Metalmann
    Dec 8, 2012
    700
    223
    Thanks, Shagas; that's a great site to study.:cool:
  7. joeyd999
    Jun 6, 2011
    2,756
    2,916
    And is this ADC tied to (or integrated in) a MCU? If so, why not perform the filtering digitally? Eric007 can help you!
  8. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  9. Shagas
    May 13, 2013
    802
    74
    The ADc is an AVR adc so yes , integrated. The avr is already busy doing a load of other stuff so I didn't want to introduce digital filtering.
    Thanks for the link bertus
