Buck reg design, which parts can be slightly different?
Discussion in 'The Projects Forum' started by kostoglotov, May 12, 2016.
  1. kostoglotov
    Jan 27, 2016
    I want to build http://www.hobby-hour.com/electronics/lm2576hv-adj-buck-regulator-schematic.png
    From http://www.hobby-hour.com/electronics/lm2576-step-down-switching-regulator.php
    I might not be able to source exactly the same parts. I assume I have to use the same IC, but could I use a, say, 200uH inductor instead of a 100uH? Or slightly different types of capacitors, with different capacitances? How about that Zener diode?
    If I'm stepping down 24 to 3V and drawing up to 400mA, I'll probably still want to attach a heatsink, no?
    edit: the output voltage will be running a small 3V gear-motor system needing to lift a small amount of weight (half to a couple of kilos) vertically in a reasonable amount of time.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It's really not a good idea to substitute parts randomly without having some idea of what the compromise involves. Circuits can cease to function or become unstable with spectacular results.
  3. george4657
    Apr 12, 2016
    Download the data sheet. It will give you data on selection value of different items and you can design a circuit based on the values you can find.
