Buck Convertor using IR2101 problems
Discussion in 'The Projects Forum' started by zami123, Jan 24, 2012.
  1. zami123
    Jan 11, 2012
    Hi everyone,i have almost read all the posts realting to the buck convertor but havent got any solution to my problem.I am using IGBT mg300H1UL1 in the convertor.The gate of Igbt is connected to ATmega 16 from which i am generating pwm. I am using IGBT driver Ir2101.But problem is that whenever i put IGBT 300H1U1,the i.c blown.I have made the design of i.c on proteus with mosfets 840 and everything is working fine but replacing with mg300H1Ul1 ,the i.c blow..Any one kindly help me with the problem...????
    Can i common the ground of the power supply of i.c and IGBt????
    Attached is the schematic..
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    What is the switching frequency?
    What is the switching speed of the IGBT. IGBTs are usually much slower than MOSFETs and that may be your problem.
    zami123 likes this.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    What is your deadtime?
    Why are there no gate resistors?
    Do you have an oscilloscope?
    Post a picture of your layout.
    The maximum negative voltage at LO and HO can only be 0,3V. That's not a lot.
    Switching can cause negative transients at the output pins, a gate resistor helps to reduce that. It also avoids ringing due to wire inductance and gate capacitance.
    zami123 likes this.
  4. zami123
    Jan 11, 2012
    Dead time????
    Where i have to attach the gate resistor.Between the HO and gate of IGBT.????
    Yup i do have the oscillocope.
  5. zami123
    Jan 11, 2012
    i am generating pwm at 4 khz from ATmega16.
    H cn i measure the switching frequency of igbt???
  6. praondevou
    Jul 9, 2011
    2,936
    489
    How much time passes between turning off one IGBT and turning on the other IGBT?
    That is controlled by the signals at HIN and LIN.
    Yes, a gate resistor from HO to the corresponding gate and a gate resistor from LO to the corresponding gate.
    Try 10 ohm to start with.
