Buck converter
Discussion in 'The Projects Forum' started by jayzac, Jan 12, 2011.
  1. jayzac
    Apr 24, 2009
    6
    I am designing a buck converter to step down the voltage down to 12V. What is the difference in choosing the power transistor between pmos and nmos for this design ?
    Thank you.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Step down WHAT voltage?
    If it's mains powered, the output must be isolated from mains power by coupled inductors (ie: transformer).
    For buck-type designs, N-ch MOSFETs require a high-side driver. P-ch MOSFETs don't; but their gate charge is ~2.5 times higher than that of an equivalent N-ch MOSFET. This means the gate drive needs to be considerably "beefier" than that of an N-ch, otherwise high power dissipation in the MOSFET will result.
    http://www.smps.us has lots of good information on switching supplies.
  3. jayzac
    Apr 24, 2009
    6
    The design is to step down 20W solar panel of Vpp about 18V to 12V. So the pmos is applicable in this design by just using a normal npn transistor to drive the pmos ?
