buck converter
Discussion in 'General Electronics Chat' started by pokiko, Sep 17, 2009.
  1. pokiko
    Sep 17, 2009
    Hi guys
    I need a power supply design has 3.3V 30A input and 2v 40A output(may adjusting the output voltage by pwm). I am thinking of build design with pic microcontrols by triggering a mosfet. I have never made such a design before so i am newbie.
    So, How can i realize such a circuit?
    Can you give me such a design examples? or any ideas about the driving part and mosfet?
    Best regards
  2. steinar96
    Apr 18, 2009
    239
    Since SMPS are usually quite complicated i recommend you buy a IC that does most of the work for you for example
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1236
    This is a configurable 5V/3.3V switchmode regulator. This one however does not handle currents over 2A. There are also good books on the subject if you want to design one from scratch. But overall designing SMPS's from scratch is alot of work.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    What is your input power going to be?
    John
  4. pokiko
    Sep 17, 2009
    input power will be nearly 80-100W. 2A output is too low for us. We need more than 40A output. And input voltage does not need to be 3.3V. It may be higher. We may do it by dc-dc step down convertor or with pwm control of mosfet.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Is your input power AC (mains) or DC, e.g, batteries?
    John
  6. pokiko
    Sep 17, 2009
    our input is a dc voltage.
