Buck Converter with Variable input Voltage
Discussion in 'Homework Help' started by notoriusjt2, Oct 19, 2010.
  1. notoriusjt2
    Feb 4, 2010
    209
    i dont know what values to use
    before this was mysteriously deleted, i think TNK stated to use the lower voltage with the higher power. is that correct?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You misrepresent me.
    I said the lower power (75W) higher input voltage (60V) condition.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I think this is readily verifiable. My argument would be as follows:
    If the minimum current just reaches zero amp then the minimum value of L to permit this would be
    L=(Vs-Vo)*D*T/Imax
    If one "normalizes" the value of L with respect to the switching period T then ...
    L/T=(Vs-Vo)*D/Imax
    L/T increases as Imax decreases and as (Vs-Vo)*D increases.
    These two conditions give the highest required inductance at the lowest power + highest input voltage case.
  4. notoriusjt2
    Feb 4, 2010
    209
    so
    L=(Vs-Vo)*D*T/Imax
    L=[(60-20)*(20/60)*(1/100000)]/(75/60)
    L=[(40)(.333)(0.00001)]/1.25
    L=[0.00013]/1.25
    L=106.6uH
    somethings still not right...
    Imax=75/60 right? or would I use the higher wattage for Imax
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Keep in mind that the mean inductor current is (Imax+Imin)/2
    At 75W and 20V Imean = 3.75A
    If Imin just hits zero amps (the limiting condition) then Imax=2*3.75=7.5A.
