Buck Converter Testing
imraneesa
Joined Dec 18, 2014
227
Hello everybody,
i want to test buck converter. i know pin sw is switching pin. but when i tried to check the waveform using my oscilloscope i am not getting any oscillations. i dont know if i am doing it right. i have set the oscilloscope 5v/div and 10us also tried 10ms.
fp7103 is the chip. i have not connected any output load. just gave input voltage 8v.
Thank you,
Regards,
Imran
ronv
Joined Nov 12, 2008
3,770
Hello everybody,
Thank you,
Regards,
Imran
It needs a load.
34,470
When a switching regulator reaches it's specified voltage output with no load it has to stop or the output would go above the control voltage. That's why it needs a load if you want to see its switching operation.
