Ok, thank you for explaining. Basically what you have is not a voltage problem it is a design problem. The first thing is you need to decide on what your setup will do in peak wind power situations;Hi, the problem is I will have to add a belt transmission to increase the RPM of the permanent magnet alternator to achieve useable power at average wind speeds. I can fabricate the transmission. If there are wind gusts the input can exceed 450 volts.
A. Convert all the power to electricity and store in battery
B. Dump some or all excess power into a short or load
C. Draw only the power needed and let RPM and voltage rise
This is a standard problem in wind generators.
My suggestion would be to look at using the PWM to give you some control over the power drawn from the mill, which will give your controller more options. That would be option A but with some intelligent control;
For instance if it increases PWM duty during peak wind it will load the turbine down and reduce it's RPM significantly, which will lower its efficiency and reduce the problem of how you will deal with excess power. It also means the voltage from the generator will be much lower (compared to open circuit freewheeling in peak wind).
During lower wind conditions your controller can optimise the PWM using a MPPT system to give you the max possible power into your battery.
If the cap issue strill troubles you it is easy enough to pair two 450v caps in series to make a 900v cap. For switching devices many of the TV HOUT transistors and PSU FETs are rated for >1500v at a few amps and are very rugged in general.
