Buck converter design help
Discussion in 'The Projects Forum' started by sumanth724, Apr 10, 2012.
  1. sumanth724
    Apr 9, 2012
    6
    hiiii....
    I am searching for a buck converter circuit whose input and output parameters are as follows
    when input is around 40v output should be around 15v
    when input is around 100v output should be around 35v
    so my buck converter range of operation will be as
    v in -- 35 to 100v
    v out -- 15 to 35v
    can any one please help me to design such a circuit...
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    You know, a 3:1 step-down transformer would come very close to meeting your specs.
    Hey, this is just a continuation of your existing thread. You really shouldn't start multiple threads on the same topic.
  3. letsbully
    Member
    Mar 23, 2012
    34
    You might be able to use TL783 in your circuit. It's an adjustable step-down IC .There are examples in the datasheet, starting from page 10, that show you how to adjust the IC to your voltage.
