Buck Converter Closed Loop
Discussion in 'General Electronics Chat' started by onceinalifetim, Dec 7, 2014.
  1. onceinalifetim
    Feb 9, 2014
    27
    Hello
    I really need help in this. i know how open loop buck converter works,
    but i don't know how does closed loop buck converter works.. pls help
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,546
    512
    What do you need to know about this? There are various aspects of the circuit.
    Also, do you already know how a linear (non switching) regulator works?
  3. ian field
    Oct 27, 2012
    4,447
    791
    Maybe the first thing you need to decide - is PWM or burst mode.
  4. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Well in a closed loop system the output voltage is monitored and some aspect of the control is altered to raise or lower the output voltage ass appropriate.
  5. onceinalifetim
    Feb 9, 2014
    27
  6. ian field
    Oct 27, 2012
    4,447
    791
    One of the simplest PWM buck designs is the hysteretic.
    There are some reference designs incorporating linear type regulators as voltage sensing devices incorporated within a hysteretic design.
    IIRC; the TL431 application notes include such a circuit example - most of the main manufacturers include pretty much the same examples in their appnotes, but the hysteretic design isn't in every manufacturers offering.
  7. crutschow
    Mar 14, 2008
    13,469
    3,356
    In general a closed-loop buck converter feeds back voltage from the output, compares it to a desired reference voltage, and adjusts the PWM duty-cycle to keep the output voltage at the reference voltage (negative feedback).
    If you use linear feedback, the loop will generally require some frequency compensation circuits to stabilize the loop and prevent it from oscillating.
    If it's a hysteretic (bang-bang) converter than you don't need compensation.
  8. onceinalifetim
    Feb 9, 2014
    27
    @crutschow thanks the tips. i roughly know what is going..
    do you have any website link regard of get the transfer function of buck converter???
