The comparator will not be able to sink the 49mA required to keep the zener in regulation; or if it does, it will be damaged.What do you think will happen with a 1N4733A? Slow turn on of the MOSFET?
I've already ordered the MOSFETs, unfortunately.
Rds(on) is specified as 0.05 (50m Ohm) when Vgs=-4.5v; 0.07 (70m Ohm) when Vgs=-2.7v.Looks good. Thanks. Gotta love a conductance of 0.005Ω. The amperage looks good for future projects too (like my 6.5A power supply).
My objection to it's selection is that in the datasheet for the Zener, Izt (Zener test current) is specified as 49mA; and the LM339's output is only capable of sinking ~1/10 that much current before its' saturation voltage becomes excessive. Getting Vgs to -5v quickly ensures that the Rds(on) will be minimal. Now, this particular MOSFET will turn on suitably if Vgs gets to ~-3v - so the 1N4733 might work, but one would have to test them to see what the actual breakdown voltage was for the current going through it. It's a case of using a part outside of it's specifications; one might work and nine more might not.OK, I have the new MOSFETs in, but before I go there I need to go over some things (IE, the zener).
In this schematic the zener is solely to prevent putting too much voltage on the MOSFET gate. As such it isn't that critical, as long as the minimum saturation voltage is met.
Well, the Zener that I linked to IS an off-the-shelf part (and dirt cheap, too); but you won't find it at a local Radio Shack store.The 1N4733a will not do that, but a large zener voltage will in the same family. Remember, part of the design goal here is off the shelf parts. I had to order the MOSFETs special, and I would have ordered the zeners if I had thought of it on time.
Here is an experiment I ran with the 1N4733a. The odd selection of numbers for currents is for logarithmic graphing. I replaced the resistor as needed to select between ranges.
..........Voltage
Current....Drop
100 µa....3.25V
178 µa....3.44V
316 µa....3.66V
562 µa....3.89V
1.00 ma...4.10V
1.78 ma...4.32V
3.16 ma...4.52V
5.62 ma...4.69V
10.0 ma...4.83V
17.8 ma...4.94V
31.6 ma...5.02V
56.2 ma...5.09V
100 ma....5.16V
Basically the minimum voltage drop has to turn the MOSFET on all the way, and we're cool. I am figuring this is at 5V for the MOSFET, and no more than 10V across the gate source at maximum voltage.
Anything wrong with this argument?
Max Vds for that MOSFET is 20v, which I mentioned before. You should keep the input voltage under 20 unless you want to kill the MOSFET. There simply were not any other viable options from that distributor in a TO-220 package.I originally stated the target voltages are 6V to 24V (maybe 30V). I'm going to have to look at that again, but those are the numbers I'm striving for.
With the voltage divider formed by R4/R5 I don't think it will do it, I'm going to have a second look at those values while I'm looking at the zener circuit. I'll set up an experiment similar to above only with the R4/R5 values included and see what the zener does.
A 1N4739 has much too high of an Izt specification (28mA). People will have to test each of them at the current which will be flowing through them, as iin this application t's just too far out of the specs.After typing all of the above I'm rethinking these specs, 6V to 10V across the gate/source. A zener of 9.1V (1N4739A) would do this nicely. I'm aiming for a 6V - 30V power supply, so I'll test it to 15V, then after all the main tests I'll go for the 30V spec in steps.
I suggest you put a small heatsink on that fet and monitor its temperature. It is rated to 175°C so it should be able to get pretty hot before it toasts, but running it at 175°C for a long time will significantly shorten its lifespan.My first test, the one that smoked the first transistor, was a ammeter as a load. It is theoretically a constant current source, so it should be able to take it. We'll see.
The second one, using a circuit board, I'll play with some component values. For example, the 4.7Ω will become a 10Ω to see if it affects performance.
Since the logic level MOSFET is fairly limited on voltage I'll use my power supplies limit of 15V as the max voltage.
One of the things I did a little differently is I beefed up the traces carrying the 0.7A current.
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Jake Hertz
