1. Aharon Finkelstein
    Dec 29, 2014
    Hello all
    I need to generate a voltage from buck-boost DC/DC block
    As the following: the input is fix to 12V
    The output should swing from 5V to 30V.
    As I never did it I ask if it's doable ?
    Is buck-boost DC/DC topology can handle that large swing?
    Aharon
  2. ronv
    Nov 12, 2008
    3,398
    1,455
    The short answer is yes. But the current is unknown.
  3. Aharon Finkelstein
    Dec 29, 2014
    thanks ronev
    i am talking on :
    The output should swing from 5V to 30V @ 1A.
    as well as is LTC3789 will do the job?
    Aharon
  4. cmartinez
    Jan 17, 2007
    3,698
    2,779
    Yes it should, although, judging from the datasheet, it's not a simple chip to use...
  5. Aharon Finkelstein
    Dec 29, 2014
    thanks.
    yea................. it's not a simple chip to use...
    I will be glad to get a good simple competitor IC for that..
    Aharon
