Buck Boost Frustration
Discussion in 'Homework Help' started by crazyengineer, Jun 6, 2012.
  1. crazyengineer
    Dec 29, 2010
    156
    Hello! I was working on my simulation for a buck boost converter. Here are the specs I originally assumed
    Vg=24
    Vo=48
    Io=1A
    delta Il=100ma
    It worked on the ideal case, but when I tried implementing real transistors to the buck boost model, I get different results
    Can anyone give some advice on what I did wrong with my model?
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    Can't suggest anything without knowing the difference between the simulation results and the real circuit results.
