Hi every one
I'm trying to build a dc-dc buck boost converter. the gate driver is IR2117. I connected the driver as the datasheet explained. the Vcc of the IR2117 is 15V is connected to pin 1. Pin 2 is connected to PWM(50% duty cycle). Pin 3 is the ground of both Vcc and PWM. Pin7 is connected to the gate of the MOSFET while pin 6 is connected to the source of the MOSFET. The neutral from the output resisnace is aslo connected to the pin 3 of the gate driver. by this connection I could obtain a DC output. I surprised that with changing the output resistance, the DC output voltage is also changed. Is there a problem in my connection. Is there an isolation problem? can you help me please.
If you can help me please contact me on:
<SNIP>
<SNIP>
