buck-boost circuit for flashlight
Discussion in 'The Projects Forum' started by Greg G, Feb 15, 2009.
  1. Greg G
    Jan 25, 2009
    8
    I've been modding lights for about a year and have the mechanics and machining behind it understood to a fashion (machinist by trade). I want to move up to building my own circuit so that I can have a better understanding of the electronics part of it.
    The first driver I'd like to build is for a Cree XR-E LED which has a Vf of ~3.7 @ 1.2 amps. The battery is a single Li-Ion which has 4.2 volts fresh off the charger, and about 3 volts when depleted.
    I was looking at the National LM5118 IC.
    http://www.national.com/pf/LM/LM5118.html
    Can anyone give me any pointers/advice on what I'm about to do?
    Thanks,
    Greg
  2. Bernard
    Aug 7, 2008
    4,232
    414
    The specs. say it should work, go for it. Are you including a charging ckt?
    Missed the operating V of battery.
  3. Greg G
    Jan 25, 2009
    8
    Sorry, fixed it. It is an 18650 Li-Ion that is 4.2 volts when freshly charged. It is rated at 3.7 volts nominal. So it is above the Vf of the LED at the start and needs to be bucked, then drops below it and needs boosting towards the end.
    I charge these batteries out of the light.
